Old 01-14-2015, 07:00 PM   #1
Krieger
So the Bentley Manual is really lacking so I will add to it:
FWIW: My car is a 99
* Before you disconnect your battery park your windshield wipers so that they are straight up.
* Disconnect battery, negative side.
* Remove drivers seat. Funky ass plug...pull out two blue pins, then you slide the center section of the switch back, then it pulls in two pieces.
* Remove trunk lever assembly. Loosen the three allen bolts a few turns. Don't take bolts out. Pull up entire two handle assembly. It can't go far because of cables
* Remove fuse panel cover. See this picture. To do this pull off the smaller cover by hand and then remove the 4 Phillips screws and pull off the big cover.
* Disconnect the cable from handle and pull the cable forward.
Krieger is offline   Reply With Quote
