Old 01-12-2015, 06:31 PM   #769
particlewave
Kevin,
1) No. High beam rotation has been disabled because he now has true bi-xenon HIDs.
2) Yes, the projector rotates with suspension load (both high and low beams).
I'm not sure what part you are referring to...?
Do you mean the silver bit ahead of the reflector and under the inner plastic shroud? If so, it is a separate removable plastic piece (interchangeable)
