as long as you disconnect the battery before you even start pulling out the seat and then use the connector when you reinstall the seat and seat belt belt connector before you reconnect the battery, you will be fine for the airbag light. I think there is a DIY here on the forum.
Too bad you wasn't closer, I have a GT3 rep seat that has been sitting in my basement for 3 years, you could give it a try to see if you like it...
