Ahhh - I forgot you guys have cats on your headers.....but the cat delete pipes are very doable.
Even so, coating just the outside of the headers is a more permanent solution to wrapping. I've coated a number of motorcycle and car headers - both new and used. If the coating specialist is competent, he will be able to advise you accordingly. The coating really does reduce localised heat around (or in) the engine bay / exhaust area and supposedly speeds up exhaust gasses.
2001 MV Agusta F4.
