Old 01-08-2015, 04:16 AM   #5
Timco
I am my own mechanic....
Timco's Avatar
Update: In less time than it took me to type my whiny post I put the top partially up after warming up the garage a little and got it off. This was my 3rd or 4th time getting the top cover off and it is faster everytime.
I am in there to finish my water pump change and install an underdrive pulley. Man it looks tight back there
Take your 20 or 22mm socket, whichever fits on the belt tensioner bolt, and grind off about 1/4 to 3/8" from the open end on the side of a grinding wheel. Then use a breaker bar to get in there. Makes for very easy access to the tensioner bolt. Same may be needed for UD pulley bolt.
Do you have the step by step for the UD pulley? You need to use the boss in there, then cut it down. You will also need a shorter belt. Took me several trips to get the right belt.
'08 VW Touareg T-3 wife's car
