Originally Posted by Keddie
MNBoxster:
What is your opinion on digital torque wrenches? How do they compare to beam?
Thanks for everyone's input. I really appreciate it.
Keddie
Hi,
All can be very good. But, the Beam Type is the simplest, so less to go wrong and more accurate readings.
The digitals have a complex mechanism which converts the mechanical torque into an electrical signal and subsequently an LCD Readout. I guess that the cheap ones won't match the accuracy and longevity of the more expensive ones. They are all bound to be relatively fragile because of the sensitive electronics they contain.
The important thing is to keep it calibrated and don't play rough with them, keep them away from heat and humidity and it'll probably serve the DIYer well...
Happy Motoring!... Jim'99
