I solved this issue easily by repositioning the elastic strap two holes shorter on my 2008 phase 1 Boxster.
1) open top to about 70 CEntimeter from windscreen
2) undo 2 velcro straps to allow access between iner liner and external top
3) use short screwdriver with fitting torx bit to release elastic strap fixed on wishbone.
4) fix strap back two wholes shorter
5) reposition not to tight two velcro's
6) repeat on other side if needed
Good luck
