Old 01-05-2015, 09:09 AM   #13
hemonu
hemonu's Avatar
Originally Posted by Madmax08154711 View Post
I build the following cable and did a test with a PST2 and an 2000 Boxster S and everything seems ok.
Be careful! With this cable you bridge Terminal 30 and Terminal 15 inside the AMP connector. If you plug the cable with ignition switched OFF you will energise Terminal 15, which may easily blow some fuse(s) or do other harm. You better do only one of the two terminals to AMP contact 5. It doesn't matter which one.
hemonu is offline   Reply With Quote
