Old 01-04-2015, 11:51 PM   #4
KRAM36
Need For Speed
KRAM36's Avatar
Originally Posted by Retroman1969 View Post
Yeah, may never happen again, who knows.
If I had to make an uneducated guess: Fuel pump getting weak, fuel regulator has slight leak, water in fuel.....
There has been no check engine light, so I'm going to assume it's not something like an O2 sensor.
The last time it got that cold, the car ran very rough until it warmed up, so there is definitely something about the temp getting below 20 degrees overnight that isn't agreeing with the car.
KRAM: I'm wondering if your sound is your fuel pump? Especially since you first noticed it after the car acted up for the first time.
The pump noise I hear is just like when you first start up the car. You will here a slight pump noise then it goes away. I'll pull up to a stop sign and hear that exact same noise. Not every time I stop, but occasionally I hear it.
