Thread: 20" wheels
Old 01-04-2015, 10:27 PM   #10
KRAM36
Need For Speed
KRAM36's Avatar
Finding 18" aftermarket wheels for a Boxster is becoming almost impossible, not Porsche styled.
Yeah I'm rethinking the 20" deal. The same wheel comes in 19x8.5 47 offset front and 19x9.5 45 offset. I can't seem to figure out a tire size for that set that would rotate at the same speed. I do want to run 235 tires on the front and 8.5" wheels are ideal for that size.
Same company makes this wheel here.
19x8.5 and 19x10 with a 5x130 bolt pattern, but the hub bore is 71.7 and the Boxster hub bore is 71.6, not sure if that would cause an issue, like the wheel not being centered correctly on the hub?
With those wheels I could run 235 front and 275 rear, which rotate at just about the same speed.
