Old 01-03-2015, 03:34 PM   #2
Cebu
Jamesp,
My car is a 2002 Base model Boxster, 5 speed manual. I could see the smoke coming from side vents after I stopped. You're right the car still has the odor of something burnt. This was a couple hours ago.
I didn't notice the brakes getting spongy during the event but I can check now if that makes any sense?
Should I start the engine and see if the brakes feels differently?
Any feedback is greatly appreciated.
Originally Posted by Jamesp View Post
Year and transmission type is usually helpful. You said the car was smoking. Could you smell the smoke? A burning clutch usually fills the cabin with acrid smoke that tends to stick with you awhile. Did your brakes get spongy (thinking clutch slave cylinder leak here). I've been through a few clutches and they warned me by slipping a bit in higher gears (second gear a favorite) under load and then catching again as the load was reduced.
Cebu is offline   Reply With Quote
