Old 04-13-2006, 05:53 AM   #1
986Jim
Springs and shocks are seperated when they are pulled out together. You use a spring compressor to take some of the tension off and you can unbolt the shock as it runs through the center of the spring. You can then replace whatever piece you need, spring only or shock only whatever. Then you compress the spring again and put the shock through and bolt it all together again and re-install.
The stock shocks will last depending on your driving habits and road conditions. Eventually they will fail prematurly because they are operating in a zone now 1" or 1.5" less than they were originally designed to do. That put additional strain on the shock operating in a shortened travel distance and causes them to fail early. Who knows how long you will get you may get a long time like stock, you may not. Just watch the shocks for signs of scaring on the rod or leaking oil.
986Jim is offline   Reply With Quote
