I did the OBC hack several years ago and also used a switch in one of the blank spots, on the dash, next to my right hand. Mine was done before Wayne published anything on it and the gauge cluster had to be removed to access the pin connection for the switch to work and the only thing I would add is if you do it that way is to put a towel on the dash to rest the cluster on while you are working on it as just the weight of the cluster will make a mark in the dash upholstery. It was well worth the effort to enable it.
