Old 12-31-2014, 10:56 PM   #2
nieuwhzn
nieuwhzn's Avatar
Look on Amazon for a split AC. They're easy to install yourself for less than $1,000. The most important part of the install is to evacuate the unit before releasing the refrigerant, I.e. you need a good vacuum pump and vacuum gauges.
You can use the split unit for heating but as the outside temperature drops this gets rather inefficient, remember thast it is just a heat pump. I'd rather go with electric baseboard heaters.
nieuwhzn is offline   Reply With Quote
