Old 12-29-2014, 12:57 PM   #2
Brad Roberts
Brad Roberts's Avatar
I'm using the Fuchs (we have it here) but I'm running MUCH thicker than anyone listed here (full race cars) My 5sp trans failures dropped dramatically with the thicker gear lube. I found the gear lube coolers to be a band-aid. All the cooler did was keep the standard issue gear lube from breaking down. So? Run a thicker gear oil. We are not trying to drive the race cars in 30deg. weather. I just pre-run the car prior to the first session and let the engine temp and rotating input shaft of the trans warm things up
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
Brad Roberts is offline   Reply With Quote
