Old 12-29-2014, 01:46 PM   #5
Brad Roberts
Brad Roberts's Avatar
The main issue I see with *some people and their home brewed solutions?? (Jegs catch can) they forget that it needs to DRAIN back into the block!! They keep draining them into a pan outside the car and forget THE OIL NEEDS to go back into the engine LOL (I've seen this on track cars multiple times) then don't understand why the engine is low on oil
The aircraft industry has used AOS style devices for years.
The Porsche solution? add capacity so it has MORE time to drain back. The real issue is: the smaller ones do NOT have time to drain back into the engine when ran hard. Porsche knew they had an issue in the Boxster's in 03. They changed the block to match the 02 3.6L drain back. The steel tube inserted into the block was nearly twice as big as the opening in the 2.5/2.7/3.2/3.4 M96 engines.
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
Brad Roberts is offline   Reply With Quote
