If it won't rise all of the way when manually operating the switch then you either need to replace or repair the regulator. A search of this site will show you how to repair the most common failure that results in the window not closing fully. If the window fails to rise fully when using the one touch function perhaps you need to do the "re-learn" procedure from the owners manual.
Mike
