Old 12-22-2014, 09:13 AM   #10
Smallblock454
Lits, without the leveling sensors, are perfectly fine if they are meant for the low beam alone (e.g. city cars). If you are able to manually adjust them to the recommended height/aim they shouldn't blind incoming traffic. The high beam won't work indeed but still it gives the driver the impression that it does. Intensity doubles... and that seems to work for some.
Hi,
well maybe that works for some. But the Litronic auto levels the xenon beams when turned on.
So you run an optimal level at low beam and high beam. Without the automatic leveling system the benefit of the Litronic will be very low. This system really works very good and makes a real good light. But it needs the leveling system to work good.
I'll try to make a video.
Regards
Markus
