Old 12-22-2014, 06:21 AM   #40
Smallblock454
There are different aspects on warming up an engine.
1. Catalysators: The had to warm up fast, because else they can not work (environment aspect)
2. Water temperature and pressure: It is good to warm up an engine in general. There hould not be very warm and very cold spots. Because of the very big water reservoir of the Boxster engine it takes time to comletely warm up the system. Water pressure is low on idle. Better is to have a little higher revs - 2.000 - 2.500 rpm.
If you have a water pre-heating system you can warm up the whole engine. This will really save fuel and prevent the engine from wear.
3. Oil temperature an pressure: The oils needs to get fast everywhere when staring the engine. The viscosity of oil can help to do that. No oil circulation means maximum wear. That's why they use 0W oils which are very thin at low temps. Also you'll have less oil pressure at idle. So it's better to start the engine and drive away at low rpms - let's say 2.000-2.500.
Also best would be to build up oil pressure before starting the engine (ignition kill switch).
4. Technology. The engine engineering in the 986 was good in ti's time. Today technology, materials and engineering are much more refined in detail. But that doesn't mean that the engine design is antique.
5. The real cold start is over at the moment the engine sparks and runs. Becuase than you have more than 500 degrees celsius in cylinders and exhaust.
My opinion: Start the engine, put seatbelts on and drive away at lower rpms and don't push the engine.
Regards
Markus
Smallblock454 is online now   Reply With Quote
