Old 12-19-2014, 06:44 AM   #1
delubozparts
Vendor
delubozparts's Avatar
Smile F/S 986 Boxster & S 97-04 Performance Schedule 40 Headers $599.99 Free Shipping
Porsche 986 Boxster & Boxster S 2.5L / 2.7L / 3.2L 97-04 TOP SPEED Performance Exhaust Headers
New Release Header Application from Top Speed Pro-1
3mm Thickness Piping in Schedule 40 Material / Triple Penetration TIG Welding / Will not break on Piping and Welding
Lifetime Warranty on This Header as long you are original owner
List $649.99 / Special Introduction offer for First 5 Customer $599.99 Free Shipping within 48 States USA
*** Not Legal for California Due to CARB Exempt # Required
We are located in Dallas,Texas
For more picture reference this is the Link:
Porsche 986 Boxster 2 5 2 7 3 2L 97 04 Top Speed Schedule 40 Performance Headers | eBay
Descriptions on Schedule 40 Material Specs:
Schedule 40 pipe, Galvanized
PRODUCT DESCRIPTION
Basic Use:
Schedule 40 pipe for use as end, corner or line posts, and rails, for commercial, industrial and institutional installations Schedule 40 pipe is the historically used material for this purpose. The requirements for this material are contained in various government specifications for use in road, dock, airport, housing, forestry, and military installations.
Schedule 40 pipe is typically used in installations which incorporate zinc-coated or aluminum-coated steel chain link fence fabric, although it may be specified for use with other types of fabric, i.e. PVC coated.
Standards:
American Society of Testing and Materials International ASTM F1083
American Society of Testing and Materials International ASTM F1043 Group IA
American Association of State Highway and Transportation Officials AASHTO M 181 – Grade 1
Federal Specifications RR-F-191/2E and RR-F-191/3E
Army Corps of Engineers UFGS-32 31 13 Federal Aeronautics Administration AC
150/5370-10E ITEM F-162 Department of the Navy U.S. Department of Justice – Federal Bureau
TECHNICAL DATA
Galvanized Steel Framework:
The information contained herein for hot- dipped galvanized welded steel pipe covers two options of ASTM F1083 hot-dipped galvanized schedule 40 welded steel pipe, Regular Grade and High Strength Grade. The accompanying tables show the different options have the same dimensions, wall thickness, weight per linear foot, galvanized coating and tolerances. The Grade signifies the yield strength of the schedule 40 pipe.
Grade Yield Strength:
Regular Grade - Yield Strength, min.30,000 psi High Strength Grade - Yield Strength, min.50,000 psi
Coating Requirements:
The Pipe shall be coated inside and out by the hot-dip process. The average weight of zinc coating shall be not less than 1.8 oz/ft2 of the outside surface and 1.8 oz/ ft2 of the inside surface. A 2.0 oz/ft2 zinc coating weight is available upon request. A conversion coating is also applied to the interior and exterior surfaces to protect against corrosion and white rust.
MAINTENANCE
Periodic inspection is recommended but no routine maintenance is required.
Thank you for Business & Support !
John Che Lin
John (Che) Lin
www.topspeedauto.com
http://stores.ebay.com/TOP-SPEED-PRO-1-PERFORMANCE/_i.html?_nkw=porsche+&_cqr=true&_nkwusc=porche&_si d=24549228&_rdc=1
http://www.facebook.com/profile.php?id=100001535057084
delubozparts is offline   Reply With Quote
