Another option would be to use a side scoop to feed air over the top. One of my side scoops provides direct air into an air box with my air filter located in the trunk. The other provides air directly in to cool the engine and starter. It also has twin fans located directly above the engine built into the engine cover which are activated by a switch. I have tracked the car in 100 degree temps and never had the oil go above 240 degrees and water temps sit right at 190 and that is with a stock 3.6L engine and oil cooler.
