Old 12-17-2014, 01:47 PM   #13
Jamesp
Beginner
Jamesp's Avatar
I've tried everything from 0- 40 to 20-50 oil in my car and the startup rattle does not go away. I've also replaced the lower two tensioners with no change. one of these days I may replace the upper tensioner but for the moment I just live with the start up rattle.
You might ask Jake if he will part with a couple of his master link chains so you can cut yours out and replace them with new without the inconvenience of removing and completely disassembling the engine. It may be stretched (read that worn) chains contributing as much or more to the rattle than weak tensioners.
2003 S manual
