Old 12-17-2014, 02:16 PM   #12
Steve Tinker
Steve Tinker's Avatar
Min thickness of front rotors = 20mm
ditto rear = 18mm
You have to use a micrometer to check the thickness as you can't get a vernier over the lip....
The problem not changing brake fluid is its absorption of moisture from the air - not good for master & slave cylinder bores & pistons especially in a high humidity climate....
2001 MV Agusta F4.
