Hi All.
Been reading this thread with interest I also have installed the German soured indicator switch i.e., when it’s going up it flashes the Red light and stays on permanently while it’s up, but then flashes when it is on it’s way down, then it stays off, just to clear up what I think might confuse people this is not a rocker switch that “Allen” has installed; that switch is off a 996 turbo and dose work as a rocker switch, I have installed both a few years ago, they work fine and yes the indicator light switch is a fiddle job but doable with minor mechanical/electrical knowledge.
With the rocker switch you can put the spoiler up at any time, but when you do this manually it will stay up until you manually put it down using the rocker switch, it will not come down at 50 MPH automatically, however you can retract the spoiler with the switch at 60 MPH for some reason you don’t have to wait for your speed to drop to 50, well mine dose anyway.
Just for those of you wondering the bottom switch is for my DRL.
Guvs.
