Old 12-11-2014, 09:03 PM   #1
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by jarrodblake View Post
I'm in the middle of stripping down the car, I need to remove the dash bar, wiring harness and hvac etc. The bar is loose but its still attached to the fire wall. I would like to pull the bar with the peddle assembly and steering column still attached, is this possible?
This diagram may be helpful:
Also anyone know what type of socket I need to remove the security nuts on the airbag module?
To remove the airbag module the manual says to use Tool 9259, which is a special socket.
This thread has a pic and also one guy says, "Vise grips work... ": Tool P 9259 to remove tamper proof bolts - Rennlist Discussion Forums
