The ground is solid since I made sure after putting in the new fuel pump and reconnecting the battery. When I said losing power I mean a loss of just engine power. Electronics are fine the entire time.
This cutting out doesn't happen every time I take off, but more often right after a stop. If the pedal has a dead spot wouldn't it happen every time? I think it's happened at various throttle inputs, especially when taking off and needing quick power, when you need to merge quickly, I'll just start off and lose it then it goes back to normal.
I've been bumped from behind but nothing major, just a scratch at stoplight. I've owned the entire time.
Black/Black 987 2005 S
