Originally Posted by Jamesp
You can use a jumper battery to operate the front trunk release even if your battery is dead. The instruction booklet in the fuse panel door shows you how to do it. From there you have access to the battery.
James, I tried the fuse box option but it only made the alarm sound when I touched the terminal with the 12volt power source, hood still wouldn't open.
