Originally Posted by woodsman
No but it may be a completely dead batt. There is a cable in the pass fender area that will release the frunk lid. It may be reachable through the towing hook hole on the front bumper. If it's not there you need to remove the pass wheel and liner to locate it. What 'power port' are you referring to- Cig lighter?
Woodsman, I hooked a 3amp battery charger/maintainer through the cig lighter last night before I went to bed and around 3:30am the alarm started to sound (very muffled and slow) and I turned it off by using a key in the door. This morning the battery showed completely charged on the LED display on the charger although everything in car was completely without power. Thanks for helping with this, I just hate to take to shop if its an inexpensive relay/fuse or battery issue.
