Those were easy
I torqued all those to 35 ft lbs per Pedro's instructions. I simply installed the 4 studs using a 1/4 inch drive 7mm socket until they bottomed out and were tight...then the nuts. The bolts that you never actually take out are the ones I could not get a torque wrench on. If the coolant hoses were removed it would be a pretty easy job.
