Thread: AOS assessment
Old 12-05-2014, 02:16 PM   #3
Steve Tinker
Steve Tinker's Avatar
^^^ Steve beat me to it as I was typing ^^^
As long as its easy to remove the oil fill cap, you (normally) don't have a failing AOS, but if you want to sure, remove the throttle body & AOS to manifold vacuum line and check for pooling oil.
The engine will run poorly with the cap removed as you are introducing a big vacuum to the system....
2001 MV Agusta F4.
