Old 12-04-2014, 08:45 AM   #23
Heiko
Heiko's Avatar
Originally Posted by Shadow_40 View Post
I am a noob to Porsche maintenance (though not to car and engine work in general)
I have oil all over my head cover area (both sides) and am having to add 1 litre of oil every 300 miles or so, so I ordered a tube of sealant to refit the head covers, a set of plug tubes and seals. It's a 2002 Boxster S by the way.
If that much oil leaks out every 300kms you must be able to see where its coming from... if not wash the outer cam shells off (or spray them down good with brake clean) and see where the oil comes from.... If the tubes leak just replace the tubes (they should come with new O-rings) The old rings get hard after a while and don't seal well... common issue... IF the oil is leaking at the cam shell seam itself you will need a proper cam hold down tool before you attempt to loosen off the shell (its not just a cover) as its actually the outer support housing for the cams.
H
Previously owned:
