Old 12-04-2014, 12:49 AM   #4
Steve Tinker
Steve Tinker's Avatar
Disconnecting the battery will also remove the CEL memory but it will return if the problem persists.
If you have disconnected the battery, you need to configure the throttle body as well - the car will do this automatically but it takes a few completed heat cycles.
Throttle body synchronisation = disconnect / reconnect the battery, switch on ignition for 60 seconds (all dash lights lit) but don't start engine. Switch off for 15 -30 seconds and then start he car.
2001 MV Agusta F4.
