Old 12-03-2014, 08:12 PM   #1
Krieger
Hey Dwight. I just did this two weeks ago. I used a car ramp I had. You know one of those angled ramps with a flat spot you drive up on? I put that directly under the engine and then I used a scissors jack, just like the one in your front trunk, on top of the ramp. If you use the factory jack it has a bump on top of it, so you might have to come up with something. Maybe drill a hole in a 2x4 to fit it. A hydraulic jack might lose pressure and leave you in a bad situation...
Krieger is offline   Reply With Quote
