Old 12-03-2014, 11:19 AM   #1
Bigsmoothlee
Technicians are taught to never let the battery go dead or disconnect the terminals in Network/CAN bus cars (especially Mercedes), because you can trash a control unit on the interior bus if the power is removed while its going to sleep. The terminals should be kept hot with a booster pack and jumper wires during a battery replacement.
Some computers may be "stuck on stupid" even after resetting with the scan tool, requiring a hard reset. For example, if the dashboard would be indicating a transmission malfunction, and you perform the repair and fix the codes, the light may continue to stay on even though faults are no longer stored in the transmission ECU. A hard reset corrects this.
Why are you disconnecting the battery? Why not leave a trickle charger on it?
Bigsmoothlee is offline   Reply With Quote
