			I am a noob to Porsche maintenance (though not to car and engine work in general)
I have oil all over my head cover area (both sides) and am having to add 1 litre of oil every 300 miles or so, so I ordered a tube of sealant to refit the head covers, a set of plug tubes and seals. It's a 2002 Boxster S by the way.
having found this thread I suspect I might have wasted some money on the sealant. Do you good folks think just replacing my plug tubes will fix the problem or do I actually need to remove, clean and refit my head covers? (I mean is it likely all my oil loss is from the plug tubes/O-rings?)
If I fitted the tubes and seals and found that my head covers were leaking would the plug tubes be reusable or need replacing again?
