Old 12-02-2014, 07:48 AM   #193
seningen
seningen's Avatar
Originally Posted by stephen wilson View Post
I think a Accusump quickly runs out of oil under sustained cornering/oil starvation. Isn't the best solution (and the most money) still adding a scavange pump to the other cylinder bank, in addition to a deep baffled sump and extended pickup ? A water/oil heat exchanger would also be a great idea.
What is the pumping rate of the oil pump? Accusump typically has 3 qts under
about 60psi.
I wonder if the pickup sucks air -- which drops the pressure -- but now you
are shipping around aerated oil as well as your pressure drop?
I wonder if there is something to temperature, aeration, and oil starvation
that comes into play at the same time.
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
