I just delt with this today. Top stopped working this week.
With the ignition on, pull up on the parking brake… does the “Park” light on the dash come on? If not the culprit is probably the parking brake switch. I was unable to entirely remove the center console but by removing the ashtray and the window switch panel I could see the switch. It is toward the back of the brake handle mechanisms. Luckily my problem turned out to be a loose connection. I pushed/reseated the plug into the switch and I was back in business.
The relay for the top is up under the driver side of the dash, it is a large relay box almost entirely covered with a white label, with a black arrow I think. Check to see if that relay is firmly seated.
Hope that helps.
