Old 11-27-2014, 09:01 AM   #3
The Radium King
The Radium King's Avatar
the 3.2 is potentially more reliable. better oil cooler, additional radiator, larger brakes, forged pistons (2.5 has cast pistons). also, the 3.2 came later in the design cycle; earlier cars have failures not as often seen in the later cars - d-chunk failure, more prone to ims issues, etc.
the spec series does use the early 2.5 cars, but note that they incorporate many of the 3.2 improvements - additional radiator, larger oil cooler, ims retrofit. I would factor in the cost of these modifications when evaluating the cost of purchasing and maintaining an S vs non-S car.
also, the S has improved suspension geometry, but the shocks are still non-adjustable. and construction quality is the same with both, although trim levels may differ.
