Old 04-09-2006, 08:07 AM   #2
MNBoxster
Originally Posted by Rail26
MN,
Great post...what do you mean "Standardized the Windows"?
Hi,
Welcome Back BTW! Standardizing the Windows is required anytime the Battery, the wiring harness or the Motor are disconnected. The Power Window Regulator loses it's reference point for the Closed Position.
To re-establish this, you need to fully raise the Windows (with the Top up) and hold the switch depressed after the Window reaches its peak for 5 sec.
Also, you lose the one-touch control after the same types of interuptions and so must also re-establish this. This is done by running the Window one complete cycle - Up/Down without interuption. Hope this helps...
Happy Motoring!.... Jim'99
