Old 11-26-2014, 10:20 PM   #1
Cebu
When my alternator started going out I had a bunch of panel light warnings come on too. There were lights coming on I never knew existed. Long story short, I read the forums and symptoms and decided to replace the alternator.
There is one cable most instructions I read required removal. The access to the cable is from the top engine cover. Instead of doing that I disconnected my battery and went about the normal alternator replacement process. A few notes..
- I did not remove the top engine cover
- I did not remove the passenger seat to access the panel. I'm a fairly big guy and I was able to maneuver around
- I did not buy an original Bosch alternator, I bought one from O'Reilly for about $160
- I did not go the route of replacing the regulator only
- I did not give up when I thought somebody cruelly welded the alternator in place
- I did sigh in relief when the automotive parts store verified my alternator was bad
The alternator was my first dive into the Porsche engine and if you have or can borrow a few tools it's a good confidence builder. At least it was for me.
Good luck and let us know how it goes!
Cebu is offline   Reply With Quote
