			So checked around and finally located drains.  One was covered with some debris which was also rust colored making it difficult to see.  The other was on the side facing toward the battery, almost impossible to see but I ran a small cable tie through the opening in the wheel well and it came out on the other side.  ALthough I cleaned up battery tray when the prior battery leaked, I didn't clean up the surrounding compartment area so residue gradually made its way into the drains.  Cleaned out the compartment area, used some CLR and flushed both drains, scrubbed the wheel well and looks like I should be good to go now.  Thanks for the help guys!
