Thanks for the thoughts - I have searched but forums but not much has been discussed about the early '97's - as I understand they have a DME that is not able to be re-flashed.
You mention removing a second air system, I presume you are referring to secondary cats - that is the issue, there is only a single cat on the early '97's.
I am ready to forget the cat delete at this point as I do not want cel's.
Thanks-
