Hey man, that's my car!!! (I wish). Thanks for posting this pic here btw
Tom - if you want the exact same results, other than the Turismo kit, you'll need additional:
1. High temp black spray paint (matte or semi/satin finish)
2. Silicon base sealant (to reseal your lens)
3. Some #600 abrasive paper to prep the surface of the reflector before painting
You may want to weld your new connections, electric tape is 'fine' however soldering those and securing everything with heat shrink wraps/tubing is recommended.
4. Soldering gun/lead kit
5. heat shrink wraps
Can't think of anything else. Some flat bars or large flat screw driver to pry open the headlight. That's it really. Let me know if you have an questions or aren't sure about anything you'll find in this thread mate
