Old 11-22-2014, 05:39 PM   #11
jdlmodelt
Originally Posted by Duezzer View Post
Hi there. Update on progress
Installed a set of plugs that are one heat range hotter. Car took 3 attempts before it started. I let it run for 20 min to warn up really well and clear out any residual fuel. Went to back it out of the garage. It stalled right away. Then hard to start. Once running again tried to back out again. It did the same thing. Shut down as soon as there was any load on the engine. Also tried to move it forward. Same issue. Very hard to start. Lots of spitting and sputtering then suddenly it catches and runs very smooth. Sometimes when it just fires up after a hard start if I let it go down to idle to quick it also quits running. When I say it quits it is a quick shut down. No spitting or spurting just quits. Looking for any ideas.. thanks in advance
Dang! No power sounds like the timing is not lined up right to me. Maybe its just a lot of air in the fuel but after running for 20 minutes, seems like there would be no air in the fuel system. If she ran fine before you changed the IMS, there should be no new issues. You didn't jump a tooth? You re checked any wires you took loose for the IMS project? Hmmmmmmm...........
