99mm sleeves will give you 3.6L with stock crank & rod length. Keep in mind this takes about 6 weeks thru LN. Most oe style mufflers are 1"& 7/8" inlet with a few 2" aftermarket options. I believe 2" is fine for street use. DME will adjust fine either way you go.
