Old 11-19-2014, 08:06 PM   #1
ChrisZang
ChrisZang's Avatar
I have a good sized job coming up, new trailing arms, new parking brake shoes, rebuild or re lube and install new boots on the CV joints and new wheel bearings on the rear.....also in that lineup is a new Motor Mount...I have everything sitting in my garage and I was pondering the question. Is it a lot easier to replace the water pump once you have the motor mount off ?
My water pump is not giving me any problems, no noise, no leaks nada....but my Bavarian Beauty just turned over 70 K miles and well...should I or wait for problems ??
Dwight
It makes no difference if the motor mount is on or off
You write "my Bavarian Beauty" did you accidentally buy a BMW and think it's a Porsche? Porsches are not from Bavaria. Hint: if the engine is up front it's actually a BMW ;-)
