Old 11-19-2014, 04:10 PM   #43
Qmulus
inveniam viam aut faciam
I update the parts available in the first post.
Also for sale,
Fourth stalk for OBC (bolts on to your existing column switch with two screws which are included) WITH wiring harness to cluster $100
I will also include a cluster from an '01+ non S manual, showing 0 miles (so you can have mileage matched) with OBC enabled for $100 It is missing the lenses and adjuster knobs. Swapping the front of the cluster housing out and swapping in the knobs requires the removal of two screws and a couple of clips. Pictures to follow.
I will also be selling an '01+ S manual with dot matrix OBC instrument cluster, also showing 0 miles, with a four stalk column switch and harness for OBC. Inquire.
Qmulus is offline   Reply With Quote
