Old 11-18-2014, 01:16 PM   #7
dmboxster
Also, pinch off the hose at the throttle body that connects to a hose going under the driver side intake tubes. If the trim values go to normal, the problem is the valve connected to the hose.
I will give that I try. I wonder if that may have something to do with it. During the AOS repair I removed the air intake manifold on the passenger side. There was some oil residue inside it most likely due to the AOS being on it's last legs. Perhaps that oil damaged or clogged up the one way valve attached to the driver side vacuum. I can try to pull it and see if there is oil within the hose going to the secondary vacuum system.
dmboxster is offline   Reply With Quote
