Old 11-18-2014, 07:36 AM   #1
dmboxster
STFT spikes of -98.4% causing P1128/P1130 on 2001 Porsche Boxster. Need Help!
I have a 2001 Porsche Boxster 2.7L with about 55,000 miles on it. Recently I have been getting CEL for P1128 and P1130. I have an ODBII with some recording capabilities and was able to record a driving session with STFT for both banks. I looked through the data and for the most part it is within the +- 10% mark. LTFT was set to +3.3% on both banks. What I found in the data that was very interesting is that there are short spikes of -99% trim on both Bank 1 and Bank 2. This only occurred once on each bank over a 20 minute drive
I believe this is what is causing the P1128 and P1130 codes to occur. I just don't know why the trim would spike to this for short times. Below is an example of the data:
LTFT1 +3.3%
LTFT2 +3.2%
TIME STFT1 STFT2 MAF Air Flow
115.5 -3.1 -3.9 0.73
115.953 -3.1 -1.6 0.73
119.297 -3.1 -98.4 0.73
119.703 -3.1 -98.4 1.92
120.094 -0.8 -98.4 1.92
120.5 -0.8 -2.3 1.92
120.891 -0.8 -2.3 2.08
121.297 -3.1 -2.3 2.08
122.594 -3.1 -5.5 2.08
124.391 -3.1 -5.5 2.55
768.453 1.6 3.9 1.49
768.797 2.3 3.9 1.49
769.141 2.3 0.8 1.49
772.203 -98.4 0.8 1.49
772.5 -98.4 0.8 1.49
772.797 -98.4 0.8 0.6
773.094 -0.8 0.8 0.6
773.453 -0.8 -2.3 0.6
773.797 -0.8 -2.3 0.56
774.141 0 -2.3 0.56
774.453 0 0.8 0.56
The car does not run poorly in any way. Here's what I have tried so far from suggestion in this and other forums to resolve P1128/P1130:
  • Replace AOS (replaced 2000 miles ago for unrelated issue)
  • Check Oil cap for air leaks
  • Clean MAF sensor with MAF sensor cleaner (engine runs more smoothly now)
  • Check air filter (replaced 2000 miles ago)
  • Checked for disconnected vacuum hoses
  • Check that oil cap seal was not leaking
From the chart above, it seems like the MAF is doing its job. Perhaps there is some faulty wiring that is causing a short to battery or short to ground causing the intermittent spike. Has anyone seen something like this before, or have any ideas what could be causing it.
dmboxster is offline   Reply With Quote
