JF
I use Plexus on mine, it does wonders for the window. Use a totally clean cotton terry towel, really soak it well with the Plexus, then rub with pretty good pressure in a circular motion. Clean up with another clean cotton terry (or you could use microfiber I suppose), again in circular motion. It really will improve your window a lot. I try to do it about once a month or so. Plexus is sometimes hard to find locally, though I have found it at a Home Depot store. Motorcycle shops supposedly carry it too. If all else fails, order online. If you get streaks, you are doing it wrong. Their use instructions are not really what you should do, use my technique, which someone told me about. Forget who that was, but it really is the way to do it.
